Bob Leffler's RV-10
Date:  3-14-2009
Manual Reference:  26-6
Brief Description:  Fuel tank and started rib to fuselage attach
Validated that there were no leaks in the left fuel tank. I drained the water, which took quite awhile. Then I cleaned and primed the areas internal to the wing on the left tank.
26-6, Steps 1, 2, 3, 4, & 5
Cleco'd and match drilled the rear seat assemblies, rear seat ribs, and the baggage ribs, to the fuleselage bulkhead.
