Bob Leffler's RV-10
Date:  3-30-2013
Number of Hours:  6.00
Brief Description:  Rudder Trim and Panel Switches
I installed the Aerosport Products rudder trim. I had to fabricate a mounting bracket for the rudder trim. I reduce the shaft length about a quarter inch so the knob didn't stick out too far from the panel. I also attached the two arms, one to each of the rudder bars. Then I attached the two lines to the springs.
I re-attached the PIDG connectors to the bay of swiches in the panel. Unfortunately, I ran them over the support panel instead of underneath. This means that I had to take them off, rerun the wires, the attach them again.
Rudder Trim
Rudder Trim
Rudder Trim Control Arms
Panel Switches
Panel Switches
