Bob Leffler's RV-10
Date:  2-22-2012
Number of Hours:  1.50
Brief Description:  Annuciator Wiring Change
I had to add a wire to each of the input and output DB-9 Connector 1's for the annuciator board. This was for the CO Guardian alert to show on the LED annuciators on the panel. I then splice the CO LED ground to the other ground feeds.
I still have to finalized the annuciator board by clipping several diodes to determine which inputs are high or low.
