Bob Leffler's RV-10
Date:  2-12-2012
Number of Hours:  4.00
Brief Description:  Ignition Switch Wiring, Magnetometer Mount, & Door
I finished terminating the end of the ignition switch wiring and laced the wires.
I installed the right door to the cabin cover.
I started to fabricate a tray for the two magnetometers. They have to be in the same plane as the EFIS, with only a 2/10ths variance allowed. I installed the left panel insert to estabish the angle of incidence of the EFIS.
Ignition Switch Wires
Panel Insert
Panel Insert
Start of the magnetometer shelf
