Pulled the wires for the nav and strobe lights to the tail.
Moved the roll servo cable from the left side to the right.
Installed the fuel line received from TSFlightlines. I will need to order a new piece.
Modified and installed the moutning brackets for the AFS 4500s. Need to test fit with the autopilot and the Gemini PFD. I'll have to drill out a few rivets that I set today to take the left bracket off to trim for the PFD clearance.
Installed two snap bushings on the wing spar bulkheads for the wiring going to the left wing. The bushings installed per plans are at capacity.
Match drilled the insert mounting holes in the carbon fiber panel. There are a couple holes that moved from the original insert locations. The next session I'll need to see what impact that has on the panel support bracket.
