AeroLEDs posted to VAF a recommendation to use three conductor shielded wiring to minimize noise with the LEDs. So Brad and I pulled out the wire for the strobes and nav lights and replaced it with shielded wire.
I spent some time doing more lacing and cleaning up a bit.
Brad installed the manifold pressure sensor and I crimped the connectors.
Brad and I install three adel clamps on the firewall to support the power feed to the VP-X unit and the ground line going to the forest of tabs.
Last shot of the upside down upper fuselage assembly
