Bob Leffler's RV-10
Date:  12-4-2011
Number of Hours:  4.00
Brief Description:  Fans and Door Relays
Brad assisted me in mounting the two defroster fans. We had to pick up some new screws on the way to the hangar.
I installed the door switch relays and wired them.
Brad also prepared the fuel line mount points under the front seats. He had to make the holes a little larger to accomodate the new stainless steel teflon tubing.
I found a couple issues with the wiring of the annuciator board. I will have to fix during my next session.
Defroster Fans
Defroster Fans
Door Switch Relays
Door Switch Relays
