Bob Leffler's RV-10
Date:  12-7-2008
Number of Hours:  1.00
Brief Description:  Started left flap
Assembled and cleco'd left flap. I also cut the trailing edge pieces. It's already for match drilling.
I also had to replace my air regulator this afternoon. When I fired up the compressor, it started leaking from inside the valve. That cost me a couple hours of build time today. Since that was the second Husky regulator to go bad, I purchased a Kobalt brand this time. With my luck, they are both probably built in the same Chinese factory.
