Brief Description: Fuel Senders, Fuel Guardian, and Fuel Vents
On both fuel tanks I installed and sealed the AN832 fitting on the inboard rib for the fuel vent line. I also installed and sealed on both tanks the fuel sender and the Fuel Guardian. The Fuel Guardian is a low fuel warning indicator that has a sensor installed in the fuel tanks from Aircraft Extras.
The next step is to install and seal the rear baffle. The light at the end of the tunnel is getting very bright. I'll be glad when I don't have to work with Proseal so frequently.
