Brief Description: Mounting left leading edge to the wing spar
Brad and Janice assisted with installing the left leading edge assembly to the wing spar. We had a few minor alignment opportunities to overcome. I left off a rivet on the leading edge that I didn't notice (Brad discovered it) until after the leading edge was already riveted. I had to use a blind rivet, since I wasn't about to drill out all those rivets to fix this one rivet.
