Brief Description: Bottom wing skins and pitot mount
Brad assisted me today with several items.
He sanded the overlaping botton wing skins per the plans.
We got the heated pitot tube mount installed and cut the holes through the left bottom wing skin. I grounrd down the Gretz pitot mount. This is required since Gretz can't get consistent pitot mounts formed, so you have to grind the composite material down for a custom fit.
Brad sanding the overlap sections of the bottom wing skins
