Brief Description: Moved left wing to cart and cleaned up shop/garage
I didn't really accomplish much on the plane today. I did move the left wing to the wing cart and adjusted the leading edge sling so that the left wing was level.
I then started to rearrange the garage back to the normal set up, since I had to move the work tables around a bit to accomodate mounting the leading edge assemblies to the wing spars.
Now it's on to deburring and dimpling the bottom skins, ailerons, and flaps in hopes that I can get them primed and ready to go before the fuselage kit arrives.
Still no ETA on the fuselage kit. Partain is suppose to give me a date by the end of the week. I'm not in a real big rush since I really would like to get these last parts prime before I have to deal with all the new parts in the garage.
Both wings in the cart
Couldn't get the entire wing in a pic without opening the garage door.
