Brief Description: Completed riveting top wing skins
16-3 Finished riveting both top wing skins, including the problem areas where I couldn't get into with a bucking bar.
I ended up having to grind down a bucking bar to make things work. They aren't perfect, but they are good enough. Brad assisted again with the problem area, then I used the pnuematic squeezer on the outboard edge.
