15-4, Step 4. Finsihed riveting the rear spar, rear spar replacement fork, rear spar doublers, and the aileron hinge bracket to the wing ribs.
The replacement tie down brackets arrived. (I forgot to cut the originals to 7 1/8", so they are too long.) I matched drilled the tie down for the right wing.
Left Wing
Took out the bolts in the tie down bracket in preparation for it's removal.
