Bob Leffler's RV-10
Date: 8-23-2008
Number of Hours: 3.00
Manual Reference: 15-2, 15-4
Brief Description: Continued Right Wing assembly
Right Wing
14-5, Step 3. Rivet the wing ribs to the spar. Brad assisted me with the bucking. I also riveted the top and bottom of the wing ribs to the spar flange.
15-2 Step 2. Assembled the aileron hinge bracket spacer, aileron hinge bracket sides, and the bearing, then rivet them together.
15-2, Steps 5, 6, & 7. Assemble the trimmed aileron hinge bracket spacer, aileron hinge bracket sides, and the bearing, then rivet them together.
15-4, Step 4. Clecoed the rear spar, rear spar replacement fork, rear spar doublers, and the aileron hinge bracket to the wing ribs.
