Bob Leffler's RV-10
Date: 8-21-2008
Number of Hours: 2.00
Manual Reference: 14-5, 15-2, & 15-4
Brief Description: Continued left wing assembly and riveting
Left Wing
14-5 Step 3. Rivet the top and bottom spar flange to the wing ribs behand the fuel tank.
15-2 Step 2. Assembled the aileron hinge bracket spacer, aileron hinge bracket sides, and the bearing, then rivet them together.
15-2, Steps 5, 6, & 7. Assemble the trimmed aileron hinge bracket spacer, aileron hinge bracket sides, and the bearing, then rivet them together.
15-4, Step 4. Assemble, then rivet the rear spar, rear spar replacement fork, rear spar doublers, and the aileron hinge bracket to the wing ribs.
