14-3, Step 5. Riveting the flap hinge rib to the flap hinge bracket to the wing rib. There are three of these.
14-5, Step 1. Started assembly of the wing ribs to the left wing spar.
Several of the ribs had their slot #'s painted over. Usually the sharpie marks bleed through the paint. So I had to guess where a couple went. I guess I see when I start to cleco the skins if it becomes a problem.
