Bob Leffler's RV-10
Date: 4-12-2008
Number of Hours: 7.00
Manual Reference: 14-4 through 16-2
Brief Description: Left wing assembly and match drilling
14-4, Step 2 (left wing)
Enlarged hole for wire condiut
14-5, Step 2 (left wing)
Cleco wing ribs to the wing spar
15-2, Steps 1,2, and 3 (left wing)
Assemble and cleco alieron hinge brackets, final drill all holes
15-3 Steps 1, 2, 3, and 4 (left wing)
Match drill rear spar doubler plates. Cut out the aileron pushrod hole in the outboard rear spar doubler plate.
15-4 Steps 1 and 2 (left wing)
Cleco rear spar to the wing ribs, match drill all holes. Countersink appropriate holes on the rear spare and the inboard rear spar doubler.
16-2 Steps 1,2, and 4 (left wing)
Install the j-stiffners in the wing rib. cleco the top inboard, outboard wing skins, and wing walk doublers. Match drill all appropriate holes. Drill #19 holes for the nutplates on the inboard edge.
I'm sure glad that I have a pnuematic cleco gun with all the clecos!
