Fixed the malformed wing tip. The rib was off 1/32" on the bottom from the top causing the distinct curve. I drilled out the the bottom rivets. Brad assisted me in put the wing tip back on the wing. Using a couple pieces of wood, we clamped it to the aileron to enusre proper alignment. Then we drilled new rivet holes in between the previous holes. Now I have a bunch of fibegralss repairs on this tip, but being on the bottom it shouldn't be noticeable.
