Brief Description: Wing Attach and Cabin Cover Attach
44-2, Steps 1 & 2
Brad performed these tasks. He did the left side and started working on the right.
Cut apart the F-1099EFG-L Wing Root Fairing Support to make the F-1099E-L, F-1099F-L, F-1099G-L, and F-1099H-L Wing Root Fairing Supports.
Flute the vertical flanges of the F-1099E/F/G and H-L Wing Root Fairing Supports if/as required to make them follow the pattern of pre punched holes in the F-1069-L Fwd Side Skin and the F-1070-L Mid Side Skin. Cleco them to the fuselage.
Final-Drill #30 the holes common to the wing root fairing supports to the fwd side skin and the mid side skin. Remove all wing root fairing supports and deburr all the #30 holes in the supports and to the fuselage side skins.
I spent the time re-installing all the screws that attach the cabin cover to the fuselage. I'm about half way finished.
