Brief Description: Right Outboard Bottom Wing Skin
20-5, Steps 11 & 12
Brad assisted me again this afternoon. We were able to get about two thirds of the right outboard bottom wing skin riveted.
Wing Skin to the bottom flange of the rear spar, to the aft half of the wing ribs and to the J-stiffeners. Begin riveting per the callouts and work forward, inboard and outboard, leaving the three outboard most ribs unriveted. Cleco the W-1005-L Bottom Outboard Wing Skin to the main spar assembly and rib that comprises the next rib bay immediately outboard of the riveted portion of the skin. Remove all clecoes from the two outboard rib bays. Carefully, so as not to form a kink, pull the unclecoed outboard portion of the bottom outboard wing skin back to gain access and rivet the rib bay. Repeat this step on each remaining rib bay.
