Insert the W-1017 Torque Tube to Bellcrank Push rod into the wing through the most forward lightening hole in the W-1010-R Inbd Wing Rib. Attach the torque tube to bellcrank pushrod to the WD-421-L Aileron Bellcrank.
Attach the W-1017 Torque Tube to Bellcrank Pushrod to the WD-1014 AFT Aft Torque Tube Subassembly as shown on Figure 1. There are TWO washers called-out; one washer is installed inside the torque tube clevis arm along with the push rod end bearing and the other washer is installed under the nut.
Use the W-730 Bellcrank Jig to verify that when the WD-421-L Aileron Bellcrank is in its neutral position, the WD-1014 FORWARD Forward Torque Tube Subassembly is also in its neutral position. Adjust the engagement of the W-1 017 Torque Tube to Bellcrank Pushrod rod end bearings and jam nuts if/as required.
Double-check that all nuts are tight and properly torqued and that all bearings and bushings rotate freely and without binding.
