Insert a VA-162 Push rod End in the "long" end of two WD-1014 Aileron Torque Tubes until the step on the pushrod end rests on the end of the aileron torque tube. Using a #30 bit, match-drill the push rod ends using the holes in the aileron torque tubes as drill guides. Install a cleco in each hole as it is match-drilled. Mark the pushrod ends and aileron torque tubes so that the pushrod ends can be re-installed in the same orientation as when they were match-drilled. Remove the pushrod ends from the aileron torque tubes and deburr the holes. Attach the pushrod ends to the aileron torque tubes using the hardware. The aileron torque tube subassemblies created in this step will subsequently be referred to as the WD-1014 FORWARD Forward Torque Tube Subassemblies.
Insert a VA-162 Pushrod End in the "short" end of the two remaining WD-1014 Aileron Torque Tubes until the step on the pushrod end rests on the end of the aileron torque tube. Using a #30 bit, match-drill the pushrod ends using the holes in the aileron torque tubes as drill guides. Install a cleco in each hole as it is match-drilled. Mark the pushrod ends and aileron torque tubes so that the pushrod ends can be re-installed in the same orientation as when they were match-drilled. Remove the pushrod ends from the aileron torque tubes and deburr the holes. Attach the pushrod ends to the torque tubes using the hardware. The aileron torque tube subassemblies created in this step will subsequently be referred to as the WD-1014 AFT Aft Torque Tube Subassemblies.
