Bob Leffler's RV-10
RV-10
Tailcone
12-2-2007
Continuing match drilling
10-13, Steps 5-7 Completed
10-14, Steps 1-4 Completed
Matched drilled the horizontal stabilizer attachment and the elevator stop to the aft deck on the empennage.
Matched drilled the shoulder harness anchors to the longeron
Drilled the static port hole to 1/2" and matched drilled the static port. to the skin.
Match drilled the cover plates.
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
