Bob Leffler's RV-10
Date:  4-7-2007
Number of Hours:  4.00
Manual Reference:  7-8
Brief Description:  Rudder riveting, rudder trim finalize
Steps 1- 3, riveting ribs to skin
Rudder trim:
Brad I and spent quite a bit of time adjusting and engineering rudder trim modification. I also forgot about the faring for the servo arm, so I need to drill holes, dimple, and rivet.
I promised Tim and Vic that I would document my measurement and give to Tim to post. I will need to complete the documentation later this weekend. Getting the servo mounting properly with the holes that were pre cut were tough. The servo arm hole should have been further forward by about a 1/4". I ended up adding three washers to move the servo further away from the skin to compensate.
Riveting rudder trin fairing to skin
