Bob Leffler's RV-10
Date:  4-30-2012
Brief Description:  Vertical Stab Fairing and Battery Ground Terminal
The PPG sales rep stopped by the hangar tonight so I didn't get as much done as I liked.
Janice finished sanding the fairing on the vertical stab. I shot a coat of primer to see if it was done. It looks good. (Finally!!!!!)
Janice also helped me with the terminal for the ground cable. This is the last fat wire that needs to be terminated.
