Brief Description: Static Ports and Empennage Wiring
Almost all the tasks today were done inside the tail cone. Janice assisted by playing gopher since I wasn't going anywhere inside the tail. I think I spent about 2.5 hours in the tail, then add 10-15 each, to get in and out.
I install the tubing to the static ports
Installed the cabling for the rear seat belts
Drilled a few holes and installed bushings for cable pass through to the rear of the tail cone
Before Janice arrived, I ran the power powers for the ELT, NACA Vent Controller, and repair another power connection that was questionable.
