Bob Leffler's RV-10
RV-10
APRS Antenna Doubler
I drilled all the holes in the APRS antenna doubler and the fuselage.
I reverse the orientation of the bolts on each stick. The nuts were hitting, so this should solve that problem.
RV-10 Home
Ailerons
Brakes
Cabin Cover
Control System
Diversions
Doors
Elevator
Flaps
Fuel Tanks
Horizontal Stab
Lighting
Milestones
Panel
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
