Bob Leffler's RV-10
Date:  1-11-2010
Number of Hours:  1.00
Brief Description:  Lower console side panel and Andair installation
I finished drilling the mounting holes on the right lower console side panel. I also drilled the hole on the left lower consoler side panel and the center rudder bracket. I then disassembled everything. I started marking the cutouts to mount the Andair fuel valve to the carbon fiber arm rest console. In order to get the valve flush to the underside of the arm rest console, I have to cut a larger hole in the forward tunnel cover.
I decided it was a good time to stop and will cut both of these pieces in the morning when I'm fresh.
Right lower console panel
Fuel valve cut out marked on the bottom the arm rest
The dimensions are marked on the tunnel cover for cutting in the morning
