Bob Leffler's RV-10
Date:  12-5-2009
Number of Hours:  1.00
Brief Description:  Working on panel mounts
Working on the panel to install the nut plates. I had to drill the mounting holes for the nut plates, then countersink them. I then primed the alumimum support panel. I also drilled some holes to keep the carbon fiber panel attached to the aluminum support panel. They are drilled in the first photo, but are very hard to see.
All the mounting holes are drilled
I'm drilling the nut plate mounting holes using a jig
The support panel all primed
