Bob Leffler's RV-10
Date:  10-7-2009
Manual Reference:  37-3
Brief Description:  Fuel lines
37-3, Steps 1, 2, 3, 4, 5, 6, 7, & 8
Fabricate fuel lines to run from the left and right input on the Andair fuel valve and to the appropriate fitting on the tunnel wall. Fabricate the fuel line that runs from the fitting on the tunnel way to the wing root area. Bend the fuel line 90 degrees aft about 1-3/4" from the fuselage.
Install the AN6 F swivel tee fitting on the output of the Andair fuel valve.
Install all fuel lines and torque nuts appropriately.
Install the adel clamps that attach each fuel line to the F-1048-L and -R Fwd Fuselage Ribs. Insert the grommets into the fwd fuselage ribs and the F-1069 Fwd Side Skins. Insert the snap bushings into the F-1084A-L and -R Systems Brackets. Install the F-10848 Systems Bracket Clips to the systems brackets.
37-3 Completed per plans.
Fuel line exiting the fuselage in the right wing root area
Fuel lines under the right front seat
Fuel lines running from the Andair fuel valve to the fittings on the tunnel
