Bob Leffler's RV-10
Date:  8-31-2009
Number of Hours:  1.00
Manual Reference:  34-7
Brief Description:  Baggage door #6
34-7, Steps 1, 2, 3, 4, & 5
Cleco the F-1081 Left Baggage Cover to the F-1034C-L Fuselage Bulkhead and the F-1058 Hinge Frame
Match-Drill #30 the four 1/8" holes in the top of the F-1081 Left Baggage Cover into the F-1034C-L Fuselage Bulkhead, and the three 1/8" holes in the flange of the left baggage cover into the F-1022A-L Baggage Floor.
Final-Drill #30 the holes common to the left baggage cover and the F-1058 Hinge Frame. Final-Drill #40 the nutplate attachment rivet holes common to the left baggage cover and the fuselage bulkhead.
Remove the F-1081 Left Baggage Cover, deburr the holes in all associated parts, then dimple the #40 holes in the left baggage cover and the F-1034C-L Fuselage Bulkhead.
Rivet the F-1081 Left Baggage Cover to the F-1058 Hinge Frame and F-1022A-L Baggage Floor using LP4-3 blind rivets. Rivet the top half of the left baggage cover to the F-1034C-L Fuselage Bulkhead using AN470AD4-4 rivets. Rivet the nutplates to the F-1034C-L Fuselage Bul-khead and the F-1081 Left Baggage Cover.
34-7 Completed per plans
Section 34 completed
Insulation installed
Baggage door all completed
