Bob Leffler's RV-10
Date: 7-19-2009
Number of Hours: 2.00
Manual Reference: 31-8,31-10, 33-2
Brief Description: Upper fuselage section completed
31-8, Step 9
Machine countersink the holes in the F-1040-L & R Upper Fuselage Channels and F-1042-L & R Bulkhead Side Channels that are common to the F-1071 Forward Fuselage Top Skin. Countersink deep enough to fit the dimples in the forward fuse top skin. Make a dimple test sample by drilling and dimpling a scrap of .032 aluminum for an AN426AD3 rivet
31-8 Completed per plans.
31-10, Steps 1, 2, 3, & 4
Rivet the F-1003C-L & R Instrument Panel Attach Flanges to the F-1071 Forward Fuse Top Skin. Rivet the F-1003D and F-l003E Instrument Panel Attach Flanges to the F-1071 Forward Fuse Top Skin. Rivet the two F-1071 B Hand Hold Doublers to the F-1071 Forward Fuse Top Skin.
31-10 Completed per plans
I also removed the crotch strap attachment in the back seats. I’ve decided not to use a crotch strap and want to get this piece of metal out of the way so there are no accidents..
33-2, Step 1
Cleco the F-1024-R Seat Floor to the F-1005A Rear Spar Bulkhead, the five F-1017A-R Rear Seat Ribs, and the F-1018-R Outboard Rear Seat Rib. Similarly, cleco the F-1024-L Seat Floor to the rear spar bulkhead and rear seat ribs on the left side.
Upper fuselage assembly temporarily installed on fuselage
The upper fuselage skin all riveted
Back seat and baggage compartment floors cleco'd
Copyright © 2001-2013 Matronics. All Rights Reserved. |
