Bob Leffler's RV-10
RV-10
Forward fuselage con't
28-5 Step 2
Drilled the four #12 holes on each of the control column mounts.
28-5- completed per plans
Started deburring all the holes on the various parts. I got through most of the left side forward fuselage parts.
Forward fuselage bulkhead sub-assembly - right side
RV-10 Home
Ailerons
Brakes
Cabin Cover
Control System
Diversions
Doors
Elevator
Flaps
Fuel Tanks
Horizontal Stab
Lighting
Milestones
Panel
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
