Bob Leffler's RV-10
Date:  8-23-2008
Manual Reference:  13-2, 14-3, 14-5
Brief Description:  Started Right Wing Assembly
Right Wing
13-2, Step 4. Attached the spar extension to the left spar and riveted in place with the spar splice plates
14-3, Steps 6 & 7. Riveted the flange bearing to the torque tube support brackets, then riveted the assembly to the first wing rib
14-3, Step 5. Riveting the flap hinge rib to the flap hinge bracket to the wing rib. There are three of these.
14-5, Step 1. Started assembly of the wing ribs to the right wing spar.
