Bob Leffler's RV-10
Date:  4-26-2008
Number of Hours:  3.00
Manual Reference:  20-x
Brief Description:  Match drill bottom right wing skins
After disassembling the wings to get ready to prime, I realized that the bottom of the wing ribs weren't matched drilled. If you follow the plans, you don't do these steps until five chapters later. I was stumbling with what to do, when Jesse Saint pointed out the obvious. Just cleco the bottom skins on and match drill even if they aren't suppose to be done until Chapter 20.
So I had to reassemble the right wing again. I cleco'd the flap gap fairings and the wing skins onto the right wing. I then matched drilled everything. I started the disassembly process again so that I can start on the left wing next session.
Right wing upside down
Flap gap fairings attached
Right bottom skins cleco'd
