Bob Leffler's RV-10
RV-10
Rudder Assembly
Step 2
Brad and Renee assisted in the final assembly of the rudder. Brad helped me using the wooden dowl to beng the leading edge of the rudder. Each of them took turns using the pneumatic rivet puller.
Using the pneumatic rivet puller
Brad took a turn
Even Renee got to set some blind rivets
RV-10 Home
Ailerons
Brakes
Cabin Cover
Control System
Diversions
Doors
Elevator
Flaps
Fuel Tanks
Horizontal Stab
Lighting
Milestones
Panel
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
