Bob Leffler's RV-10
Date:  7-6-2013
Number of Hours:  8.00
Brief Description:  Battery Hookup, Re-install EFIS, & Ground Power
I installed the batteries. I was able to purchase a replacement terminal bolt at the local hardware store. While hooking everything up, I noticed something odd with the ground power circuit. I ended up taking the ground power circuit out, until I have a chance to do a more complete review.
I re-installed the two pilot side EFIS. I took the opportunity to replace all the DB screws, with a thumb screw.
I started work on taking the stick grips a part to insert the bushing to match fit the stick from Van's.
