Bob Leffler's RV-10
Date:  7-1-2013
Brief Description:  Brakes
Joe Strausbaugh assisted me with the brakes. After two attempts at getting the fittings in the master cylinders to not leak, Joe gave it a shot. He ended up taking the cylinders out of the aircraft to ensure all the hydrolyic fluid would be cleaned off. This is probably where I went awry.
The good news is that they are no longer leaking after we re-filled the lines and got all the air out of the lines.
No leaks from the pedals
Contraption to keep fluid off the engine and floor
