Brief Description: Fuel Flow Sensor Mount and Ram Air Control Cable
I had to remove one bolt on the mixture cable mount because it was too long. Then I proceeded to mount the fuel flow sensor mount.
Afterwards I put two adel clamps on theback of the fuel flow sensor mount for the RAM Air Control cable, as well as routing the cable through the adel clamps on the side of the RAM Air filter housing. Then I cut the control cable to length.
When pulling the cable back far enough to cut only the sleeve and not the internal control cable, there is a ball bearing that falls out of the handle. It was getting late and I need to take the dog home for her dinner, so I decided to wait until tomorrow to re-install the bearing.
