Brief Description: Engine Sensors and Mixture Control Cable
I replaced the EGT and CHT sensor connectors that I soldered closed.
I worked on the mixture control cable to get it to go stop to stop. I figured out the issue, but ran out of time to completely implement the solution. I had to take the lower center console apart in the cockpit to get access to the throttle linkages. I had to lengthen the fitting on the mixture cable a bit. I still was not quite hitting both stops, but I should be able to resolve during the next session.
Ivan Kristensen flew into town this morning. Both Ivan and Geoff Combs stopped up for lunch and to look over the project. It wasn't a very productive afternoon, but I enjoyed both of their company.
