Finsihed installing the mixture and throttle control cables. They tested just fine and they move the complete throw distance.
I then begin to work on the prop/governor control cable. I was hoping I didn't need the extension arm that some other builders needed. But it turns out I do. I will have to order it on Monday. Fortunately, Hartzell is only sixty miles awhile, so it should be here by Tuesday.
