Brief Description: Fuel Injection and Purge Valve Control Cable
I installed the control cable for the purge valve and install a couple adel clamps for stabilities. I then removed the fuel injection dristribution unit to remove a fitting that Lycoming installed for testing. Per Don at Airflow, this needs to be plugged or capped. I wanted to plug it, but I can't get the fitting loose at the moment.
