Brief Description: Rudder Trim and Alternate Static Air Switch
Installed the springs on the two Aerosport Products rudder trim arms. This was a pretty awkward task without the help of a third hand.
I installed the alternate static air switch on the panel. This switch opens the static line into the cabin should the rear static ports ever get plugged. I also installed a quick disconnect connector on the back of the switch.
