Bob Leffler's RV-10
RV-10
Left Wing Root WIring and Overhead Inserts
Add three additional conductors to the elevator trim circuit.
Install Map Lights, switches, and seat belt holder on the overhead panel inserts.
Wired the low fuel indicator in the left wing.
Finished the wing root electrical connections.
Installed the fuel line in the left wing root.
Ran the pitot and AOA lines into the fuselage.
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
