Brief Description: Antenna Cables and Drill Hole in Fuselage
I put the BNC ends on the antenna cables for the ADSB.
I drilled a 3/8" hole in the fuselage forward of the spar for the low fuel warning sensor. I originally planned on running this to the multi-connector behing the spar. I didn't realize until I put the wings on that there is no way to route the wire back to the multi-connector from the fuel tank.
