Brief Description: VP/X, Flap, and Transponder Antenna
We got the VP/X Pro installed today. The position of the mounting holes moved due to me not thinking about the final position of the ribs, which moved about 1/4" when they were riveted to the firewall. With my back problem, I was unable to get underneath the console to do any work. Geoff Combs volunteered to assist me and resolved the issue in no time.
While Geoff was under the panel, he also finished tightening the nuts on the transponder antenna.
I installed the cotter pins on the flap bolts and hooked the right flap up to the control arm.
