Bob Leffler's RV-10
RV-10
Started to install panel components
Installed the AFS EFIST, CO detector, and the ELT remote in the right panel insert.
Installed the Gemini EFIS, the AFS Pilot autopilot, switches, and the LED annuciator lights in the left panel insert.
Installed a bank of switches in the center panel insert.
The other components will wait until the inserts are installed in the panel.
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
