Bob Leffler's RV-10
RV-10
Doors, Cabin Cover, Stick, and a little proseal
Janice finished sanding the door interiors and cleaned them up. Then I shot a coat of primer and a couple top coats.
I also finished wiring the right stick connection.
Janice assisted me in closing a few holes in the fuselage with proseal.
Janice also applied some body icing to the cabin cover door frame and sanded that smooth.
Renee cleaned the glareshield and worked on cleaning the exterior of the airframe.
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
