Bob Leffler's RV-10
RV-10
Primer - Tail Feathers & Cowl
All the pieces were wiped down with MEK and a tack cloth.
Two thin coats of Sherwin Williams CM0483505, a high performance, high solids, low VOC, two-component, green corrosion inhibitive epoxy primer, were applied.
RV-10 Home
3251
Ailerons
Airworthiness
Brakes
Cabin Cover
Condition Inspection
Control System
Diversions
Doors
77
144
Elevator
541
228
First Flight
Flaps
Flying
Fuel Tanks
45
80
375
Horizontal Stab
Lighting
Maintenance
Milestones
139
Panel
118
375
Phase I
Pre-Flight
Prep
Shop
Tailcone
Vertical Stabilizer
Wing Leading Edge
272
